Roam like at home
Cbreaks2
Roam like at home
Hi I’m very new to this but I recently went to France and had difficulty with using my data.
I do have roam like at home but on my mobile it said I had lost connectivity because I had it turned off when I left the UK.
I didn’t know how to turn it on without being charged !!
Can anyone help & suggest what I turn on my mobile without being charged as I am going to Spain soon.
It will only be in Europe I would use it and know it should have worked but I wasn’t sure.
Thanks for any help.
1 REPLY 1
Fixes: 1,577
Re: Roam like at home
Hi there, if you turn roaming on, you won't be charged as long as you stay within a Roam like at Home country: https://www.plus.net/help/mobile/roam-like-at-home/
