Responding to NHS messages - failed
colourqueen
I'm trying to respond (as requested) to NHS messages on a given shortcode number and keep getting  "sending failed". How can I fix this as I need to respond.
4 REPLIES 4
LifeonMars
Seasoned Pro
Fixes: 12
Re: Responding to NHS messages - failed
SpendLessTime
Fixes: 86
@colourqueen
As the link @LifeonMars pointed you to, Plusnet do not support Short Codes. You will need to find a proper phone number for the NHS department and contact them by a phone call.
colourqueen
Thanks @LifeonMars and @SpendLessTime; not really the answer I wanted but at least it explains things. I'll try sms from my Plusnet landline. I believe that should work.  Just tried and that worked fine.
HarryB
Fixes: 256
Hi @colourqueen, I do apologise for any inconvenience caused by being unable to send sms messages to shortcode numbers.
I'm sorry to say at this time we have no information to share regarding whether this will change in future.
 Harry Beesley
