Reset voicemail to default greeting
susiee
I can't seem to find updated posts regarding this issue so apologies for duplicating.
I chatted to Mobile customer support yesterday regarding resetting voicemail to default greeting and they gave me the link to this discussion - having tried both options below - my phone just rings for ages then cuts off. The mobile is a MotoG7. Is there an alternative option to try please?
**004*+447870020555*11*30#
**004*07870020555*11*30#
27 REPLIES 27
MatthewWheeler
Fixes: 456
Re: Reset voicemail to default greeting
Thanks for your post @susiee
So we can investigate further can you PM me the following?
- Your mobile number or account number
- Your full address and postcode
- Your full name and if you're the account holder?
 Matthew Wheeler
susiee
Thank you Matthew - will do that now
VinceUK
I'm having the same issue, I've tried the options listed in other threads but with no joy.
susiee
Matthew hasn't got back to me yet (not an issue) so hopefully at some point he will also help you. I tried all the options as well listed in older threads even the iphone ones (I haven't got an iphone!) My phone just rings and rings then cuts off without an option for the caller to leave a message.
OllieC
Fixes: 46
Hi @VinceUK
Can you please PM the same information we requested from @susiee
Once you have sent the information, please come back to us here and we will get back to you accordingly.
Kind Regards
VinceUK
Hi @OllieC
I've sent you a PM as requested.
Kind regards,
Vince
MatthewWheeler
Fixes: 456
Thanks for getting back to us @susiee and @VinceUK
I've just sent you both a PM asking for some final details
Let me know via here once you've responded
 Matthew Wheeler
susiee
Hi Matthew - I have just replied to your questions
Thanks!
MatthewWheeler
Fixes: 456
For some reason, it looks like voicemail was disabled for your number.
I've reactivated it now and it should be up and running shortly.
Can you try it again and let us know if you're still having issues?
 Matthew Wheeler
VinceUK
I've sent the details as requested.
Thanks,
Vince
MatthewWheeler
Fixes: 456
Thanks for getting back to us @VinceUK
I've passed this to our Mobile operations team and requested they reset your voicemail greeting
We'll update you as soon as it's been done
 Matthew Wheeler
susiee
Hi Matthew - thanks for that however .... I have just rung the number and it does the same (ie rings for ages then cuts off without any chance/indication of leaving a message. Would I input that code again? I won't do anything until I hear from you!
Fixes: 1,576
Hi @susiee thanks for getting back to us.
I've passed this onto our mobile operations team to investigate further and we should know more within 5 working days.
Apologies for any inconvenience caused by the delay.
susiee
I have rung the number again and it is back to where I left it (ringing for ages - no greeting - silence - then "you can edit your message by using the hash key") So some of it is back!
The above is when I tried to set it up myself but didn't want my own voice so left it silent - I just now need the greeting message.
Would inputting one of those codes bring it back?
Last question - can I alter the amount of rings before the voicemail greeting answers (when I get it back) ?
Thanks for you help - appreciate it
