Re: logging into my account
Plusnet Staff
Plusnet Staff
Fixes: 78
It sounds like there might be some intermittent issues with the mobile account website that are causing it to load slowly.
Fixes: 103
Yes, I've seen occasions when it can take what seems an age (but in reality is probably about 20 secs!) to load the mobile account login screen.
Fixes: 103
It's horrendous at the moment!
First attempt to login timed out.
Second attempt worked , then getting call history took forever ( > 30 seconds ).
Finally logout timed out!! ( and said I need to login again:rolleyes: )
90505826
thanks for your reply, I began too think it was me dreaming it or being impaitient , sometimes it wont log in as you say and then others it times out, ive tried going from the community page and from a fresh welcome too login page ,both the same ,but better results overhall from the community page. lets hope the mods can put some pressure on this and get it sorted.
90505826
so  not really fixed then just then  same,
