Re: Porting over Christmas
Suecj
Hi, I gave Plusnet my PAC code and number on 20th December and received an email and text saying it would be done.  I am still waiting for my number to port over.  I messaged you and was told it would happen on 27th. It didn't so I called on 28th and today and it still hasn't happened. Whenever I call I'm told it will happen sometime today!  I have received no text messages about a delay and feel it will never happen now.  I'm getting really fed up with the delay as it has been several working days even allowing for the Christmas break. Very disappointed with the service
6 REPLIES 6
Fixes: 1,474
Moderators Note
This post has been split into its own thread for better visibility
Fixes: 1,578
Sorry to hear your port is delayed.
The most common reason for this if a delay happens is that we'd be waiting on files from every provider which has ever owned the number. Ports can't successfully complete until the files have been received.
Any outstanding ports are normally tracked and monitored. However I've emailed our operations team to check this.
We'll update you when we know more. Apologies for the inconvenience this is causing.
jgfrancis
I don't think it's correct that you need files from every provider that's ever held the number.
The only parties involved are the donor of the number, the recipient of the number and the original issuer of the number.
Fixes: 1,578
I've received a reply back from our operations team advising that we don't have an update yet and likely won't do until after the bank holiday, but we'll be sure to update you when we know more.
Suecj
Port has finally happended this afternoon, 3rd January, after a lot of messaging and chasing. Took over 5 days excluding Bank Holidays and weekends.
Fixes: 1,578
Glad to hear that the port has completed. Thumbs_Up
Apologies for the delay you've encountered.
I'd just like to note again that any outstanding ports are monitored, so no one needs to chase for this to happen, but sometimes I'm afraid it can take some time to complete due to the process we'd go through.
