Port not working properly
- Mobile
- Port not working properly
18-04-2020 1:12 PM
Re: Port not working properly
18-04-2020 1:47 PM
Sounds like you've got what called a 'split port' where the number port hasn't completed properly. It's possible that the PlusNet systems may spot the problem automatically and investigate but I would suggest contacting the CSC again. When number ports go wrong it can take a few days ( or even a week or two ) to get it sorted.
18-04-2020 3:31 PM
19-04-2020 5:07 PM
Thanks for getting in touch @Verity77
Sorry for the issues with your number port. Can you PM me the following so I can investigate further?
+Your mobile number
+Your full name
+Are you the account holder
+Your full address
