Plusnet sim card not working in my Samsung 7edge
Angelamac
I was previously with tesco mobile and the say the handset is unlocked. I get message saying sim not registered or Sim PUK to unlock done this and still not working. I put the sim in an unlocked iPhone and it works fine but this isn't the phone I want to use.
Tags (1)
12 REPLIES 12
Fixes: 338
Re: Plusnet sim card not working in my Samsung 7edge
Sounds like Tesco are telling you porkies and the phone isn't unlocked. Was the phone originally bought from Tesco ?
Did they provide an Unlock code when you asked for it ?
Mads
Fixes: 79
Hello @Angelamac,
Thanks for getting in touch.
I am sorry to hear about the problems you are facing with regards to your handset not accepting your Plusnet sim without a PUK code. I do apologise for the frustration caused.
So we can investigate this for you, could you PM me:
- The make and model of the handset you wish to use
- Your full name
- Your mobile number
Thank you.
Angelamac
The phone was my sons and he was with 02 and it was them that unlocked it for me to use my tesco sim.
Angelamac
No code from them when I called and gave them my imei number she said it was showing unlocked and told me to go back to plusnet
EmilyD
Fixes: 117
Hi @Angelamac,
I'm sorry for any inconvenience that this is causing you. I've checked your account and I can't see anything from this side that would be stopping the SIM from working. As the SIM is working in your other handset, this suggests that this handset isn't fully unlocked.
Please can you contact your previous provider again and request an unlock code?
 Emily D
Fixes: 338
@Angelamac
Moving from O2 to Tesco wouldn't require the phone to be unlocked, since Tesco use the O2 network.
Since the phone wasn't originally bought from Tesco it probably doesn't show on their systems and so they are assuming it's unlocked.
Was the phone originally on O2 PAYG or on a contract ?
My guess is that the phone is still locked to the O2 network.
Marksfish
Seasoned Pro
Fixes: 4
Tesco use O2 as their provider, so it would suggest that the phone isn't fully unlocked for all networks. You can get unlock codes online, I believe you can also request them from Samsung direct.
LaurenB
Fixes: 131
Hi @Angelamac, as some of the others have suggested it sounds like you will need to go to the provider where the phone originally came from and get them to unlock it.
 Lauren Barry
Hi Angelamac,
My friend had a similar problem with a locked phone and was messed about being told different stories and nothing getting done
I took the phone to a local market phone " We unlock phones" stall  where they unlocked the phone for £5
Took the new sim card with me to make sure the unlocking worked ok
The phone is still working on the new provider no problems
Brian A
Fixes: 338
From this https://community.o2.co.uk/t5/How-to-Guides/Unlocking-an-O2-phone-to-use-a-different-SIM-card/ba-p/1... it would appear that have been problems getting O2 phones unlocked
billnotben
Probably no help for the op but in these days of 3G 4G I've noticed a few quirks on some phones with O2 sims (and probably others using their network).
You put a sim in looks fine dials ok but the call times out and fails to connect. Phone then set to 2G only and it now works fine. Network changed back to auto 2G 3G 4G and the phone carries on working ok from this point onwards.
Angelamac
Thanks I think I will have to take it to someone I do feel as if I am getting messed about.
