Plusnet SIMs not designed for iPads?
Sunshine
I called Plusnet today to get help with the SIM I'd just installed in my iPad and was told "Our SIMs aren't designed to work in iPads" - who knew?!
4 REPLIES 4
chenks76
All Star
Fixes: 12
Re: Plusnet SIMs not designed for iPads?
presumably they mean you'd need a "data only" SIM for an ipad, and that's not something they provide.
jaread83
Fixes: 81
Looking at uswitch website, there is no mention of plusnet mobile on the ipad sims page
https://www.uswitch.com/mobiles/compare/ipad-sim-card-deals/
I thought any nano sim would be compatible with iPad but it doesn't look like this is the case.
Edit: After looking into this a little further, it looks like @chenks76 is correct and iPad sims need to be these 'data only' ones.
Sunshine
Thanks for the confirmation. I gave notice on the contract and got a SIM from GiffGaff, which works fine.
Mav
Fixes: 510
Moderator's note by Mike (Mav): I have changed the fix to @chenks76 as per message #2.
Forum Moderator and Customer
