Plan usage data out of date
PeteIOW
On my online account, the 'Current Usage' shows as between October and November 2016. I checked to see if this was just my account, but on my wife's Plusnet Mobile account, it shows her 'Current Usage', as between March and April 2016 !
Does anyone know why this should be ?
Fixes: 30
Re: Plan usage data out of date
Hi PeteIOW,
Thanks for getting in touch with us. Your usage should refresh in your 'My Account' on your bundle refresh date; I apologise if this hasn't been the case for you.
We're due a new update for the 'My Account' feature which will be released this month, so a fix will be implemented for any hiccups you're experiencing with this.
Hope this helps!
- Rebeka Smiley
 Rebeka Preston
PeteIOW
Hi Rebeka
By " bundle refresh date ", do you mean a date each month ?
Fixes: 30
Hi PeteIOW,
Yes, your bundle refresh date is the same date every month, this is when your allowance will refresh and revert back to 0.
- Rebeka
 Rebeka Preston
PeteIOW
OK, Thanks Rebeka, hopefully the update will fix this issue.
Fixes: 30
You're welcome.
If there's anything you need in the meantime, don't hesitate to drop us a message and we'll do our best to help.
- Rebeka Smiley
 Rebeka Preston
brightonbelle
I'm getting this too.
brightonbelle
Update: seems to be correct now.
PeteIOW
Hi brightonbelle,
It must be a slow process, mine still says October - November 2016 for usage.
