Plan change request almost 2 months ago still didn't go through
webchuzz
Hello,
On the 12th of June, I have contacted Plusnet support via online chat to request a change to my mobile data plan.
The request was accepted and I was told that the new plan would start on the 21st of June. Fast forward to the 22nd of June, I login to my user account only to see that I am still stuck with the old plan.
Contacted support again, they said that for some kind of technical issues the move didn't go through and that I would have to wait until next month (21st of July). So, back in the day, as a temporary measure, I was provided with a bolt-on, free of charge, similar to the plan I was about to migrate to. No worries.
Fast forward to the present day and - surprise - I am still stuck with my old plan. No upgrade has happened.
I wonder: when will I be able to get the plan I want? Otherwise I'll be forced to switch to a different provider.
MichaelWilliams
Fixes: 15
Re: Plan change request almost 2 months ago still didn't go through
Hi webchuzz,
I'm very sorry to hear your plan hasn't changed as it should have. If you could please PM me some details, I can chase this up and investigate for you.
 Michael Williams
Metalhead
Welcome to my Plusnet world...,i've attempted 4 times now in 3 months to get a tariff transfer and each "anniversary date" nothing is changed. Obviously this is a problem Plusnet are aware of but are unable to fix.
Colin_Maybe
Fixes: 8
Strange, I've changed tariff twice since joining and they've both gone through as expected.
MichaelWilliams
Fixes: 15
Hi Metalhead,
I'm very sorry to hear yours hasn't gone through either. Feel free to also send along your account details in a Private Message and I can get this looked into for you.
 Michael Williams
