Number ported, no mobile data network
gc6500
My number porting completed yesterday 🙂 however i can make calls and text ok but if i try to connect to internet without wifi i get an error
"Could not activate mobile data network, PDP authentication failure"
Any suggestions?
28 REPLIES 28
RebekaPreston
Fixes: 31
Re: Number ported, no mobile data network
Hi gc6500,
Thanks for getting in touch with us!
Can you please reset your network settings and delete any previous network profiles that may be stored on the handset. You can do this by the following:
Tap Settings > General >Reset > Reset Network Settings.
Tap Settings General > Scroll to the bottom and open Profiles > In the "Profiles" section, select the profile you wish to remove and tap Delete Profile.
- Rebeka
WS
Hi Rebeka,
I appear to be having the same issue. I've already reset my network settings (I have an iphone 6) and it doesn't seem to have solved it. Any way of helping me please? Smiley
Thanks,
WS
gc6500
Hi Rebeka,
Have already reset network settings, made no difference and have no profiles showing.
RebekaPreston
Fixes: 31
Hi gc6500,
Since your port-in, have you tried re-booting the handset at all? You can do this by the following:
  • Turn the handset off
  • Take the SIM card out
  • Leave it for a couple of minutes
  • Replace the SIM card
  • Turn the handset back on again
It's important to remove the SIM from the handset entirely when performing the re-boot, to the allow the SIM to disconnect and establish a new connection to the network upon re-boot.
- Rebeka
gc6500
Yes have also done this, still the same
RebekaPreston
Fixes: 31
Hi WS,
Can you please try the troubleshooting steps that I'm advising @gc6500.
Thanks,
- Rebeka Smiley
RebekaPreston
Fixes: 31
Can you please try manually searching for a network and if given an option, try to connect to any other network that differs from EE/Plusnet. Once you've done this, leave it for a couple of minutes and then go back and select EE/Plusnet.
- Rebeka
Alex
Fixes: 13
It is worth doing a soft reset on an iPhone too.
Takes a couple of minutes and doesn't delete any data.
(No don't whatever you do, don't try a hard reset into DFU mode - that will and be painful).
Google your iPhone model number and that will tell you what button combination to hold down for around 10 seconds.
It has happened to me where I had no mobile data and a soft reset fixed it for me.
WS
Unfortunately that didn't work nor did re-starting my phone. I don't know how to manually search for another network as my phone automatically goes to EE?
Thanks,
WS
Alex
Fixes: 13
On an iPhone go to General->Settings->Carrier, and switch the Automatic Button to off.
WS
I've now -
- Reset network settings
- Taken the SIM out and then re-inserted it after a few minutes
- Changed carrier and then reverted back to EE
- Done a soft reset
All didn't fix it Sad
RebekaPreston
Fixes: 31
Are there any previous network profiles stored on the handset WS?
If so, can you please delete these.
- Rebeka
WS
Sorry I'm a dunce at this sort of thing, I used to be on O2. How do I delete the profile?
Thanks!
Fixes: 339
