Number ported but Plusnet account not updated
- Mobile
- Number ported but Plusnet account not updated
07-12-2020 2:36 PM
Don't know if anyone's come across this before. I ported from Vodafone last week. My Plusnet sim arrived on the day the switch was due. I kept using my vodafone sim until it lost signal. Then I switched to the Plusnet sim which used its own number for a while before switching to my old ported number.
All seemed fine.
However, I never received a confirmation from Plusnet that the port was complete and the plusnet app and my phone operating system both show the number of the sim I was sent, not my ported number. It also shows no activity on my account since the port, presumably because it's tracking a number which is no longer in use. I phoned in on Friday and was told the port had not gone through (odd as I'm happily using my ported number!) and it would be sorted asap.
It's not a big problem at the moment but it does look as though the number port has gone through but somehow the account details haven't changed and Plusnet still think I'm on a number which is actually dead. I'm worried this could be a problem down the line...
Re: Number ported but Plusnet account not updated
08-12-2020 5:25 PM
Ivr been onto CS a few times but all I get is "we don't know why there's a delay!"
I've tried asking to speak to someone else but they won't put me thro, just says they won't know either.
My old number became active on 2nd Dec but no usage on app or account! Thanks
08-12-2020 8:54 PM
Mine was similar, the app took a few days before it showed my ported number
08-12-2020 11:45 PM
09-12-2020 10:05 AM
09-12-2020 10:58 AM
09-12-2020 11:01 AM
That reason you got from CS was much more plausible than just "idk"
Hopefully we'll be sorted today 🤞
09-12-2020 11:05 AM
Yeah, my partner, whose number port did not go through correctly, received the same email:
Brilliant news, your mobile number port will be complete today. While this is happening you might have a short period of disruption to your service - we suggest turning your phone off and on again every so often to make sure the changes take effect. To check that the number has transferred, simply make a test call from the phone and check that the right number is displayed on the receiving phone. If you need us, give us a call for free on 500 from your Plusnet mobile or 0800 079 1133 from any other phone. |
Thanks, |
10-12-2020 10:39 AM
10-12-2020 10:40 AM
10-12-2020 10:52 AM
- Mobile
