Not receiving SMS
- Mobile
- Not receiving SMS
Not receiving SMS
29-04-2020 5:23 PM
I've just moved to plusnet, which went well until I found I can't receive text messages, any text messages, although I can send them, make calls and receive calls from the people I've been texting.
This is a major issue as banks etc. use two stage verification which is now impossible as I can't receive SMS.
I've done the usual restarts, reinserting the SIM etc. but it's still not working.
Re: Not receiving SMS
29-04-2020 5:30 PM - edited 29-04-2020 5:35 PM
Hi
Have you set the APN setting on your phone for PlusNet look under Help & Support
What are the APN setting for my phone
I had the same problem
29-04-2020 5:48 PM
Thanks for the tip. As I have no idea what that is, that's a no 🙂
I'll see what I can find.
29-04-2020 5:58 PM
I checked the APN settings. Some weren't correct but they were for MMS which nobody uses now we have WhatsApp but I corrected them, just in case.
I still can't receive SMS messages.
