Not Registered on Network
ChasL
Yesterday I lost my Mobile connection here at OX39 4JA and contacted technical support. They said there was a problem in the area and pointed me to the EE Service checker
https://myaccount.ee.co.uk/networkchecker/checkservice
Which identified a problem. The support person also suggested I remove and clean my SIM which I did. I then waited to see if the problem had been resolved today, and the checker confirmed:
WE RECENTLY FIXED A PROBLEM IN OX39 4JA
However I still cannot connect to the network, the phone reports NOT REGISTERED ON THE NETWORK.
I have cleaned the SIM again after POWER OFF repeatedly.
I desperately need my mobile to work again. The number is valid as calling it from a landline gets straight through to my voicemail.
Anything you can do to restore my service will be gratefully accepted.
Chas.
3 REPLIES 3
ChasL
Re: Not Registered on Network
Problem resolved, this might help others.
My Phone is SAMSUNG A5 so might be different for yours.
Select SETTINGS
In the search box enter RESET
From the list of RESETS available select RESET NETWORK SETTINGS
This option will reset your Mobile Network connection status, WiFi and Bluetooth connections so WIFi and Bluetooth devices will all need to be added back in. If you're happy to do that, then click the big blue RESET SETTINGS button.
This reset does not affect email or other account settings.
The device will clear and reconnect to the network.
Mine now works correctly.
Hope this helps others
Chas
Mads
Fixes: 79
Hey @ChasL,
Thanks for reaching out to us.
I'm really glad the service is now working for you and thanks for sharing that info!
Give us a nudge if you need further assistance.
smart_123
This is very common problem we often seen on samsung devices. There may be different reason behind this problem.However,  explained 7 different methods to solve this problem
https://newsmoze.com/not-registered-on-network/
