No signal
- Mobile
- No signal
No signal
16-01-2023 10:26 AM
I have a new account, chose Plusnet as it is supposed to use EE and have good coverage - I have very poor coverage using my iphone 8 plus. Also I was in an area on the weekend where no other phone service works except EE - however my phone did not get any signal at all! This is my main reason for getting Plusnet mobile as it is supposed to use EE but it appears not?!
Before I cancel my contract I would like some information if possible if there is a fault etc?
Re: No signal
16-01-2023 1:48 PM
Although Plusnet does indeed "piggy back" on the EE network, it doesn't have access to all of the frequency bands that EE uses.
I moved from EE to Plusnet Mobile last summer, and I have found the same coverage differences between the two that you have.
From what I have since found out, Plusnet deosn't use some of the lower frequencies that EE does, and this can affect penetration into very large buildings such as shopping centres etc.
Maybe this is one reason why Pusnet is significantly cheaper than EE?
Re: No signal
16-01-2023 2:39 PM
Thanks for that, it's useful to know. It was in the countryside where I had no signal not a shopping centre. Will see how it goes though - thank you
Re: No signal
17-01-2023 10:54 AM
Hi Nic68, I'm sorry that you've been having problems with picking up a mobile signal. Please feel free to send me a private message with your full name and mobile number and I'll take a look into it for you.
Adam
Re: No signal
17-01-2023 12:47 PM
Thanks, just sent you one
