No signal since 12.45
Chey
I have had no mobile data signal since 13.45 and the message says unregistered network. Has anyone else experienced this?
2 REPLIES 2
chelsea1
Re: No signal since 12.45
Had something similar - be interested to see what the mods suggest
Fixes: 1,577
I'm sorry to see your mobile had stopped working. Is it back up now?
If you're still having issues, try typing your postcode into EE's status checker Here to check if there's a known problem.
