No signal, service checker says it should be excellent
snapper_mart
I've just moved home and cannot use my mobile as there is no signal inside the house and I just about manage to get signal if I go out in the garden. The service coverage checker says I should be getting excellent signal inside and out.My partner is on Giff Gaff and her service is fine...help !
2 REPLIES 2
Fixes: 391
Re: No signal, service checker says it should be excellent
@snapper_mart
As. no doubt you are aware Giffgaff use the O2 network and Plusnet EE.
I’m not saying that it’s the cause of your problem but be aware that Plusnet do not have access to all of the EE frequency bands and it’s possible that this is key to your location. I suspect that the service checker shows the complete EE frequency spectrum not the limited Plusnet range.
Like your partner I use Giffgaff.
snapper_mart
Thanks Baldrick1, I’ve ordered a SIM from GiffGaff and got my PAC code from PlusNet.
