No service
troop222112002
Interested
No service
I asked for some help about no service last week and I’m still no Further forward
If I can’t sort the problem it’s pointless me staying with plusnet
So if anyone can help with a couple of questions that would be great 👍
First question why can’t I make WiFi calls it doesn’t work it did work on o2 but not on plusnet?
Second question what frequency does plusnet use and would a signal boost help me like this 1 https://www.ebay.co.uk/itm/900Mhz-Cell-Mobile-Phone-GSM-Signal-Repeater-Booster-Amplifier-Yagi/38263...
2 REPLIES 2
Mads
Fixes: 79
Re: No service
Hello @troop222112002, thanks for getting in touch. Sorry to hear you are having issues with the service there.
1. First question why can’t I make WiFi calls it doesn’t work it did work on o2 but not on Plusnet?
    - Essentially as we are budget network we do not have the facility for Wi-Fi calling - no plans at the moment
2. what frequency does Plusnet use and would a signal boost help me
   - We have access to EE's 2G, 3G and the "high frequency" 4G signals. While a signal booster might help, we are unable to assist further with that query.
Thank you.
 Maddy S
RobC
Re: No service
troop
Try switching your phone to 2g/3g - no 4g
You might find you have a stronger signal. You can always just switch it back if it doesn't help.
Show us ONE just ONE real, defined benefit for the British public from Brexit
Brexit Promised cake .... But just delivers a stream of Cack
... and expects us all to just swallow it
Brexit - Built from Bovine Manure by Bots
