No outgoing calls while roaming
- Mobile
- No outgoing calls while roaming
18-06-2022 5:11 PM
Recently while on the Isle of Man I couldn’t make any out going calls. Everything else worked fine, texts, data etc.
In the call barring menu, the outgoing calls while roaming was highlighted. I tried to disable it and it asked for a password. Everything I tried didn’t work.
Once home I tried my wife’s SIM card which isn’t PlusNet in the phone and it was fine, nothing highlighted. I put my sim into her phone and again the call barring feature was highlighted. Same type of phone btw.
I called plusnet who sent me out a new sim, and said it may work, it didn’t, same issue.
It can’t be the phone, it must be down to the plusnet sim as non plusnet sims work as they should.
Any ideas or help very much appreciated as I’m away to the Isle again soon.
Re: No outgoing calls while roaming
20-06-2022 5:39 PM
I’ve just tried a Lebara and Vodafone SIM cards and they both allow calling out.
Definitely a Plusnet Sim issue it seems.
21-06-2022 11:56 AM
Hiya Colfor, thanks for getting in touch! I'm really sorry for the problems you've had in the Isle of Man, I hope you still had a good time
Are you still there now? Could you pop me over a PM with your mobile number and full name so I can take a further look.
(to send a PM, click on my name and then to the right, there will be a grey button to 'send private message' and in the message please include a link to this thread)
21-06-2022 1:17 PM
Thank you for the reply @LaurenB .
I can’t see the “send private message” button to message you,
21-06-2022 1:20 PM
@LaurenB Ignore that last post, I found it.
21-06-2022 1:32 PM
29-06-2022 9:59 PM
04-07-2022 2:50 PM - edited 04-07-2022 2:52 PM
Hi @ROBBOEDIN,
IT seems @LaurenB has the same issue with her phone.
This issue is still ongoing.
Hope it gets resolved by the time I return to the Isle of Man next month.
04-07-2022 5:25 PM
Hiya @Colfor, just letting you know that I've not had any further response off the team yet. I have sent a chaser and I'll let you know once I get a reply.
- Mobile
