No network signal for a couple of days now.
- Mobile
- No network signal for a couple of days now.
28-02-2023 3:40 PM
For the past few days I've had no network signal, getting the emergency calls only message. I live on the Wirral and wondered if if there were outages and if so when are they expected to be fixed?
Re: No network signal for a couple of days now.
28-02-2023 6:27 PM - edited 28-02-2023 6:30 PM
Plusnet uses the EE network, so you can check your area with EE's coverage checker at https://coverage.ee.co.uk/network/ee (strangely if I use a link for that address it gets a 404, but a cut & paste works).
Plusnet don't use all the frequencies that EE use, so there is always a small possibility of there being no problem for EE customers but a problem for Plusnet customers if one frequency is down (maintenance etc.)
- Mobile
