No mobile signal at new home
- Mobile
- No mobile signal at new home
on
10-08-2017
10:29 PM
- last edited on
11-08-2017
3:12 AM
by
Mav
I've just moved to [Removed] and I have no signal at all. My screen shows emergency calls only. Luckily I have wifi but to call or text I have to go out to the street.
I don't suppose there is a solution except to change providers but Plusnet says there is coverage here so how will I know the others would work?
Any suggestions other than get a sim card from each and try them
Moderator's note by Mike (Mav): Personal information removed from a public forum to an area that staff can see.
Re: No mobile signal at new home
10-08-2017 10:39 PM
this may help https://opensignal.com/
10-08-2017 10:46 PM
11-08-2017 8:50 AM
That's the only way I'm afraid, opensignal is no more use than the carriers own apps, they're suggestive only. Use the apps to get an idea of which is best and then test the top 2 or 3.
BTW EE have access to the 800Mhz band which may help but it's only for just a few phones (bought from themselves).
