No mobile service in Tobago
- Mobile
- No mobile service in Tobago
Re: No mobile service in Tobago
06-01-2023 6:04 PM
10-01-2023 12:34 PM
10-01-2023 12:35 PM
10-01-2023 12:36 PM
10-01-2023 12:36 PM
10-01-2023 12:36 PM
10-01-2023 12:39 PM
(I've posted this all in separate posts because, although I've had a Plusnet account for a while, I've not used the community before, & I've seen that I need a minimum of five posts to send a PM)
10-01-2023 11:47 PM
Neither Guyana, Barbados or Tobago are on Plusnets lists of countries you can’t use the mobile in. I didn’t even get a text to say I could use the service. so difficult to deal with plusnet no live chat service and of course it’s not possible to call as no mobile….
11-01-2023 1:34 AM
I've been chasing this all day, and that's bad enough! Over a week is really poor. Hope you get something sorted soon
11-01-2023 12:07 PM
@adamwalker / @willcutforth / @SeanD / @Gandalf / @bobpullen
Is it possible that these users who are overseas and cannot use their service are all caught up in the pre-Christmas DD failure issue and have had their international usage restricted?
11-01-2023 12:53 PM
11-01-2023 1:05 PM
@BellaVivat have you reached your Smart Cap ?
Receiving texts is the only facility that is free. Everything else will incur costs and will be prevented once you hit the Smart cap.
The actual costs are here https://www.plus.net/help/mobile/roaming-and-international-calls/ , Guyana seems to be in Band 3 and is quite expensive ( especially data at £6/MB ). If your Smart cap is at the default £10 then just turning data roaming on will have exceeded it!!
11-01-2023 3:34 PM
I use WiFi wherever possible and usually have roaming turned off. I only turned on briefly to try to send the text when I couldn't do so via WiFi. I've checked my usage and it tells me I've zero usage outside my plan
So 🤷🏽♀️
11-01-2023 7:14 PM
@Townman from what I have seen the majority of the ones that haven't been able to use are due to smart cap being exceeded and customers are not aware that having a £0 smart cap will cause them to not be able to use it.
Not sure what the others have seen but I haven't seen a correlation with the DD issue and this.
11-01-2023 7:19 PM - edited 11-01-2023 7:22 PM
