No mobile network
HELENRICE5
No mobile network
For weeks now my mobile network has not been connecting so I can't make phone calls on my samsung mobile.
I have checked the sim is in correctly but still no joy.
Any advice would be appreciated.
5 REPLIES 5
iannewson
Re: No mobile network
Try entering your postcode here https://coverage.ee.co.uk/coverage/ee and see if it says if there are any network faults
adamwalker
Fixes: 221
Hi @HELENRICE5 I've popped a private message over to you, please get back to me with the details I've asked for when you can. - Adam
 Adam Walker
Emmajb23
Hello I am having the same issues recently but today I can't use data at all.
I don't have another phone to call on and can't use Twitter as I need to verify my mobile number and unable to receive texts.
I think I possibly need a new SIM card.
Fixes: 160
@Emmajb23 and @HELENRICE5
To avoid doubt are you both in the UK?
What does this say about local EE network operations? - Mobile Network Coverage Checker UK | Plusnet Mobile | Plusnet Mobile
JulieB
Hi
I have the same issue....no mobile data but works when a different sim card is used?
Have just had a new sim from plusnet but still not working?
Any advice ? TIA
