No internet connection on Android phone when tethering.
98954176
No internet connection on Android phone when tethering.  Phone itself has a good, fast 4G internet connection but if I set up a WiFi hotspot I can connect to it OK with my tablet, but it says "no internet connection" so no browsing.
Any ideas ?
6 REPLIES 6
OliGaffney
Fixes: 7
Re: No internet connection on Android phone when tethering.
Hi there @98954176!
I'm really sorry to hear that you're having trouble tethering your data.
Is your iPad able to connect to other Wi-Fi hotspots at all?
-Oli
Fixes: 339
@98954176 try googling tether_dun_required
98954176
Not everybody has Apple products, Wink  its a Samsung Android tablet.  It's able to connect to WiFi routers no problem.
98954176
Had a look at the build.prop file but there is no entry relating to stopping tethering.
Fixes: 339
On my android phone I had to use ADB and set tether_dun_required = 0 , that fixed it for me
98954176
Hmmm, looks a bit complicated, does the phone need to be rooted to do this procedure ?
The fact that it's not working at the moment mean that Plusnet/EE are disabling internet access via tethering then ?
