No data in Spain again
Re: No data in Spain again
Fixes: 63
Thanks for getting back to us.
So that we can check into the account to find out if there's an underlying issue, can you please PM me:
- The mobile number in question
- Your name and confirmation that you're the account holder
- The full address including postcode
Thanks,
OP
Done. This is the third time I’ve sent this to someone.
Fixes: 386
Thanks for getting back to us @Stoopo.
I've just responded to your PM asking for further details.
Can you post back here once you've responded?
 Matthew Wheeler
I’ve done that. However I’ve already done this twice.
Seems pointless to be honest as it’s nearly two weeks now and I’m no further on.
Same last year. Two weeks of no data. That’s a month now in total yet you still expect me to pay as normal.
Not happy at all.
Fixes: 75
Hi @Stoopo
Thanks for providing your security information via PM - I've now escalated this to our mobile networks team for investigation and we'd normally expect an update within 2-3 working days.
Best wishes
Dave
Thanks - just in time for home!
Fixes: 75
Hi Stoopo,
Our network team have asked whether you could confirm the area of Portugal that you're attempting to access the service in and whether there have been any specific times within the last two days where you've attempted to switch network/access data without any success.
Could you please confirm so that I can feed this back for you as a priority?
Best wishes
Dave
I’ve tried in Faro, Portimao and Lagos. None work.
Fixes: 75
Thanks @Stoopo - I've passed that information across.
Fixes: 126
@Stoopo
You're certainly getting aboutSmiley
For information to all including @RandallFlagg  theres no basic problem with data in the Algarve.
I spend a few weeks in Ferragudo ( other side of the estuary to Portimao ) during the winter and data has always worked fine anywhere between Faro and there. Although I seem to recall that the  Vodafone Pt network is forbidden. Meo and Nos seem to work IIRC
@Stoopo  have you ever in the past hit your Smart Cap ?
@RandallFlagg  have the data roaming settings been checked on the back end systems.?
This is the second year I’ve had the same problem. It’s not my phone as my wife’s O2 sim works fine in my phone yet mine won’t work in hers.
I concur  Vodafone P doesn’t work at all. No signal anywhere I’ve been.
It seems that some sims must be faulty. I can send and receive texts and my voice works fine for both outgoing and incoming calls.
No doubt I’ll be home before I get an answer.
oh - also been to Feragudo and it never worked there either.
Im also nowhere near my smart cap. I’ve not been able to use any of this month’s data.
Fixes: 126
@Stoopo  I appreciate you're currently nowhere near your Smart cap BUT have you ever reached it in the past .?
Theres some anecdotal evidence that if the cap is hit then future data roaming can be affected as some restrictions may not be reset in the back end systems when the cap is lifted
Yes I have. I reached it in August and bought extra data. I also remember reaching it last July 2018 before I had the same issue last October.
you could be correct but I would have thought plusnet support should know these things?
Yes, and where and how the problematic setting can be quickly fixed,
let alone addressing the bug that is the root cause
.. as seen in other threads and already asked of PN by @MisterW
Show us ONE just ONE real, defined benefit for the British public from Brexit
Brexit Promised cake .... But just delivers a stream of Cack
... and expects us all to just swallow it
Brexit - Built from Bovine Manure by Bots
