No Service on Phone for 6 Months
- Mobile
- No Service on Phone for 6 Months
- « Previous
- 1
- 2
- Next »
Re: No Service on Phone for 6 Months
17-01-2022 9:02 PM
Could the number not have ported properly? Sorry, just thinking of ideas out loud.
17-01-2022 9:08 PM
From my reading it sounds like a mechanical connection problem. The sort of thing you might get with short phone contacts and a bent SIM not sitting flat in the carrier.
Maybe time to try a replacement SIM?
17-01-2022 9:10 PM
I will get a replacement ordered tomorrow and see if that helps
17-01-2022 9:14 PM
Yeah I think it’s worth trying a replacement.
@jenniferhunter, if you haven’t done so already, send us a message back on Facebook and we’ll pick it up tomorrow to order a replacement SIM for you.
18-01-2022 8:49 AM
18-01-2022 9:15 AM
Ah. I'd recommend asking your mum to call us (from another phone) or you can call us with your mum there with you.
We'll be able to help you over Facebook, if you're an authorised user/nominee (That's something she'll have to ask us)
18-01-2022 11:35 AM
I think I've exhausted all avenues now. The annoying thing is I checked the coverage map before taking out the contract and it said good coverage indoors and outdoors
If the 4G coverage is good indoors and outdoors what does the coverage map say for 3G?
18-01-2022 12:33 PM
18-01-2022 3:22 PM
Aside from the possibility of a faulty sim card etc. I was curious to know how good the 3G signal was as PN don't do 4G calling just 3G.
Your uploaded image just shows 4G signal coverage.
18-01-2022 3:34 PM
18-01-2022 3:51 PM
That rules out a poor 3G signal then, fingers crossed a new sim card solves the issue.
26-01-2022 4:07 PM
Did you manage to get a new replacement SIM card ordered?
26-01-2022 4:50 PM
31-01-2022 7:18 PM
That's a pity, came across this on TECHJUNKIE but no idea if it works, maybe you've g00gled the issue earlier and came upon it too 😀
https://www.techjunkie.com/samsung-galaxy-s6-no-service-solved/
- « Previous
- 1
- 2
- Next »
- Mobile
