No Service - No access to APN settings on iPhone
Forsh
I've currently got No Service showing on my iPhone 5s - iOS 12.1
I've tried resetting Network Settings
I want to check APN settings but the Settings > Mobile Data  page is blank
Any ideas?
...Now on Mobile Data page I'm getting
An update is required to use mobile data on this iPhone
Learn More
Learn more just tells what I can't do
Software is up to date iOS 12.1
8 REPLIES 8
Forsh
Re: No Service - No access to APN settings on iPhone
Seems like it's an Apple / iOS 12 issue
Sim works fine in an old iPhone 5 running iOS 10
Not found a fix though
db74
I had the same issue with a iPhone 5 and believe the problem is with the SIM failing to overwrite the APN settings, which you have no access to.  The only solution I found was to backup the phone, restore it to factory and start it as a new phone, then restore the apps, text, pictures afterwards.  I raised this with Plusnet weeks ago, but failed to receive a reply and it appears to be a common problem, just not one Plusnet are willing to admit!
MatthewWheeler
Fixes: 433
Sorry to hear this.
I've raised it to the relevant team to see if there's anything that can be done.
We'll update you when we know more
 Matthew Wheeler
Forsh
Thanks for that,
Any news?
1st world problems I know but this iPhone 5 I have to use is a surprising step backwards
Smiley
Mads
Fixes: 79
Not quite yet @Forsh, we'll let you know when we do.
Forsh
This is a screen shot of the update failed message
Dumbledore
Fixes: 34
Hello Forsh, I am sorry to hear you are having issues using our services on your phone.
Thank you for uploading the screenshot.
We have checked with the relevant people and have been advised there is no issue from our side that is causing this.
We would encourage you to seek assistance from Apple.
I am sorry for any inconvenience caused.
Many thanks.
Forsh
Thanks Dumbledore,
I should be near Meadowhall Apple store tomorrow - no appointments available online but I'll see what they say and report back
Smiley
