No Data Connection - iphone 11
skelly99
Hi -  I recently moved 5 SIMs to PlusNet.  All iphones but differing models.
Two of the phones do not get any data.  The other 3 work OK.   Phoned PlusNet and went through
1) Settings/reset/reset network settings
2) settings /mobile data/network selection - switched automatic off selected other provider -  restart phone
None of above worked so was sent new SIM.  New SIM arrived for one of the failing handsets today but still no data
Seems numerous posts around this issue but no fixes seem to work for me.
The two SIMs not working are for two of my sons so as you can imagine this is 'shocking'
Any help welcomed.
5 REPLIES 5
iannewson
Re: No Data Connection - iphone 11
Not sure if it will work but try the following:
  • To check for new carrier settings update on your iPhone 11, go to Settings-> General-> About menu. Stay on this menu for a few seconds and wait for the update message to appear. If a new carrier update is up for grabs, then it will be indicated on the message prompt. Otherwise, you won’t see any message prompt at all.
skelly99
Hi - tried your suggestion - there was no message regarding message carrier
Any other suggestions welcomed?Huh
Fixes: 1,586
Thanks for moving your mobiles to us @skelly99
I’m sorry to see two of them can’t get data.
Have you tried one of the SIMs which doesn’t work, in a phone that you know works with a Plusnet SIM?
skelly99
So managed to get these working - previous supplier was sky and in both phones there was a sky mobile profile still in place - when this was removed data started to work - I did call plusnet 3 times was sent new sims but they were unable to fix - I’m surprised plusnet could not fix as surely there’s lots of people transfer from sky to plusnet - in the end it was a lot of internet searching to work this fix out for ourselves
targetn72
Hi. I have the same issue. My previous sim was from Virgin.
How did you get it to work?
I understand that I need to update network settings just can’t figure out how. Thanks
