No 4g after travel
RCCM
No 4g after travel
After travelling to a few different countries I returned home to have only 3g.  I've tried all the usual reset of networks, removal of sim etc so a replacement SIM was suggested.  This arrived, but no luck.  All the same possible remedies tried.
I don't have the option to see APN settings (iphone 5) so can't manually add these.
What's strange is that while I had this issues when my number was porting over from EE, it did resolve itself, so I know it's nothing to do with the phone or previous profiles etc from another provider.
I'm out of ideas - anyone have any suggestions?  (Other than moving on from plusnet)
Tags (4)
1 REPLY 1
MichaelWilliams
Fixes: 15
Re: No 4g after travel
This doesn't sound right at all, RCCM, but I'm sure we can get this sorted for you.
Please send me a Private Message and I'll open up the account and start to investigate.
 Michael Williams
