Newcomer seeks advice re 2FA problems in poor reception area
scholar
I'm  a new comer to PNMob.
I live in an area which has poor coverage - regardless of provider.
Some outdoor reception  but nothing inside thick stone walled cottage.
I have been reviewing Internet security for all my devices and have started using 2 factor authentification on some sites.
However 2FA systems  which attempt to text my mobile just don't reach me.
Is there any way of boosting indoor reception or any other work around?
7 REPLIES 7
Mav
Fixes: 507
Re: Newcomer seeks advice re 2FA problems in poor reception area
If you're talking about Short-Code Messaging then Plusnet Mobile doesn't currently support this.
Forum Moderator and Customer
scholar
No not that sophisticated.
  Sites  trying to authenticate my identity often send a numerical code  via sms  which I then have to enter into a website  box to confirm receipt ( and thus confirm identity).  The SMS often doesn't get through to me.
DaveyH
Champion
Fixes: 12
SMS isn't the best way to do 2FA anyway, as it's susceptible to MiTM attacks. Much more secure to use an authenticator app that generates the one-time passcodes (where supported)
Fixes: 313
It's only sending to short codes that's not supported, incoming SMS from short codes is supported.
Fixes: 1,551
Hi there.
Unfortunately I don't think there's anything I can recommend from a staff perspective regarding boosting your signal, but it may be worth looking at using an authentication app like @DaveyH has suggested.
Mav
Fixes: 507
@MisterW
You're right, of course - no idea why I thought that. SorryEmbarrassed
scholar
My thanks to you and to daveyH  for your advice.
