New sim no service Homtom HT17 Pro
Mutti
Unlocked Homtom HT17 Pro (running android 6 marshmallow).  Received Plusnet sim, received welcome email, popped sim in, no service.  Plusnet sim works fine in Doogee handset (not mine belongs to a mate).  Both o2 and giffgaff sims work in Homtom handset.  Totally confused.  Performed factory reset on Homtom, tried plusnet sim, still no service.  Tried settings > mobile networks > access point names but unavailable (greyed out).  The sim is recognised but not accepted i.e. number not showing in phone details.
Any ideas.
4 REPLIES 4
MichaelWilliams
Fixes: 15
Re: New sim no service Homtom HT17 Pro
Sorry to hear you're having some service issues, Mutti.
Have you removed any old profiles from the handset?
Oldjim
Fixes: 63
@Mutti I had a problem with that handset and gave up  (no data connection possible although worked as a phone)
Now on O2 which worked out of the box with no fiddling
Mutti
Michael - have no idea how to do that.  Do you mean delete accounts such as google etc. Bear in mind I have done a factory reset which wipes everything  (or so I thought).  Thanks.
Mutti
@Oldjim  Thanks for heads up.  Have ordered giffgaff sim today in the hope it works which piggybacks off O2 I believe.  Fingers crossed.  Cheers.
