New mobile phone user. Understanding SIMs
Hello3
So I just purchased plusnet SIM. How can I be sure I have the correct SIM type (not SIM provider e.g. Plusnet) for the mobile phone I have?
1 REPLY 1
Fixes: 367
Re: New mobile phone user. Understanding SIMs
@Hello3
The Plusnet SIM will fit all sockets. There are 3 sizes. The SIM card comes as the largest but the actual active SIM part is the smallest. They are nested with a weak joint between each size. You just look at the size that the phone takes (or read the book) and push out the size that you require.
