Network issues yesterday
pkw
Yesterday evening I noticed I couldn't send texts. Then tried to make a call and couldn't call either. I had no data connection either briefly, but then it came back (but not texts/calls). I restarted my phone - no effect. Tried a couple of hours later and it was back to normal. Wondering what was that about? It happened once before, as I was on the phone to PN customer services actually to change my plan. The call was dropped and I couldn't make calls for a while and they couldn't reach me either. A bit worrying. I'm pretty sure it's not my phone, and the reception was showing as good. Has it happened to anybody? (I'm in the South Wales area).
P.
3 REPLIES 3
Protech
Fixes: 5
Re: Network issues yesterday
Similar intermittent problems with sending txts yesterday evening and with unanble to make calls the day before.
Swindon area.
You can check out but you can never leave ( easily)
Mayfly
All Star
I had problems Tuesday. Couldn't send text, calls kept getting cut off. I had the caller ring me on the land line in the end. Lincoln area.
srichards
I am having similar issues. Text sending is appalling at the moment.
I keep hitting try again until it sends. Takes 20 or 30 times now. It's pathetic.
