Netflix texts not arriving
sealdriver
Hi, I recently added my mobile number to Netflix and requested the verification code, they say it has been sent but it never arrives. I contacted them and they said I have to ask for my mobile provider to allow texts from them. Is this a thing? If so, how do I do it?
I've never had a problem receiving texts from anywhere else.
3 REPLIES 3
Fixes: 1,551
Re: Netflix texts not arriving
Hi there.
This is quite odd. My first thought would be that Netflix may be using short codes/numbers which we don’t support on our network, but it would appear that this only affects the ability to send to a short number rather than receive.
Have you tried entering your mobile number with and without the 0 in front?
sealdriver
Yes, I tried that but their system seems to add it back in anyway. No idea why it is happening but they are adamant they are not doing anything wrong.
Moderator's note by Adie (Dvorak) removed quote formatting.
Fixes: 1,551
Having a look into the settings of my parents Netflix account(I don't have one myself), under Communication Settings in your Account there's a box that says "Do not send me any emails or text messages". I'm assuming that's not ticked?
That said this box may not make a difference to a verification code being sent.
Are you able to use a different mobile number instead just to try to eliminate possible causes? For example using a number not with plusnet and another number with plusnet. If possible.
