Moving to EE on my plusnet sim only, how can i check handset compatibility
- Mobile
- Moving to EE on my plusnet sim only, how can i che...
16-08-2023 7:04 PM
I'm an IT technophobe. My mobile is a Samsung SM J600 FN. Will it still work as I think it only 3G? It's android version 10 if that means anything to anyone? Thank you
Labels:
Message 1 of 3
(495 Views)
2 REPLIES 2
Re: Moving to EE on my plusnet sim only, how can i check handset compatibility
16-08-2023 9:07 PM
@EmSuffolk it will work the same way as it does/did on PN.
Seems it works on 4G.
16-08-2023 9:23 PM
I hope you are right. It is a worry. Thank you for taking time to reply.
Message 3 of 3
(447 Views)
- Mobile
