Moved from EE - signal now terrible
Russell666
Was on EE and the signal was OK - now getting no signal at all indoors 90% of the time, and having to go to the garden to make calls, where it's poor at times. Are they using the same network as EE or a compromised version?
4 REPLIES 4
Oldjim
Fixes: 63
Re: Moved from EE - signal now terrible
If you were relying on 4G 800MHz then yes because that isn't available
Russell666
How would I know if I was using that?
Oldjim
Fixes: 63
Colin_Maybe
Fixes: 8
You'd need something like the LTE Discovery app off the Play Store or iTunes. That will tell you which band is being used although you'd need an EE sim in the phone.
