Mobile voicemail divert number...????
- Mobile
- Mobile voicemail divert number...????
2 weeks ago
What number should I put in here to use my voicemail divert features?
Re: Mobile voicemail divert number...????
2 weeks ago
Number is 555
Or call your own number let it go to your greeting and press 1
2 weeks ago
2 weeks ago
@tjonesuk79 wrote:
https://photos.app.goo.gl/eGxVynTP16S99g5W8What number should I put in here to use my voicemail divert features?
Welcome to the forum. 🙂
Unless I've misunderstood the question, you would enter whatever number you wished the diverts to go to.
ADSL2+ Billion 8800NL
2 weeks ago
2 weeks ago - last edited 2 weeks ago
Yep, it'll be a specific number - I am not sure if short codes work on diverts. PlusNet may be different.
I had a problem a few months back (I am on EE), when people called my mobile it would just fail. Luckily disabling all my diverts temporarily fixed it. As Freddie Mercury once said "Living On My Own" (as I do), I got rid of my landline a while back so not being able to receive calls on my mobile is a big problem for me.
It worked, but I forgot and it was a few weeks later I realised I had completly disabled voicemail. So if my phone is swiched off or I don't answer of course you don't get through to me.
Sounds like you've sorted it now. I think my problem was at the network level, not the phone in my case. Just had to do a bit of messing around disabling it and (then finally remember, did it - well done Alex!) to enable it again.
Thanks for letting people know who may have the same issue 🙂
- Mobile
