Mobile service issues
Lisamaguire11
Constant issues with voice calls at the moment can you advise when it will be fixed? I have been checking the EE service status since before christmas but no change?
1 REPLY 1
Fixes: 1,596
Re: Mobile service issues
If there's a known issue when you put your postcode into the EE Service Checker I'm afraid it'd be a case of you'll need to wait and see as we'd check the same site for outages. Sad
If there's no known issues showing, before we suggest something have you carried out any troubleshooting steps so far?
