Mobile roaming like home
Herb35
Plusnet help states: "With a Roam Like at Home enabled mobile plan, you can use your monthly plan allowance in more than 40 EU destinations, including; France, Spain, Italy and Germany."
How do I find out if the plan I have includes Roam like at Home and that it is enabled Huh
2 REPLIES 2
willcutforth
Fixes: 97
Re: Mobile roaming like home
@Herb35 Usually you will be on the plan but it should show on your online account. If not, I can have a look for you Smiley
 Will Cutforth
Herb35
I could not find a definitive statement tell me on my on-line account - it merely hinted that it should be (perhaps someone would review the wording!) I'd be grateful if you would confirm that my account does have roam like home.
