Mobile network not available for voice calls.
ronaldduncan
This seems to be plusnet's go to message that comes up randomly when I try to make a call.
It usually lasts a few seconds and I just try calling again and it goes away and the call goes through.
Any idea what is going wrong.
2 REPLIES 2
Fixes: 1,586
Re: Mobile network not available for voice calls.
Hi @ronaldduncan
Can you enter your postcode into EE's service checker Here and click on the check network button?
There may be a known issue on the infrastructure. Let us know what you find out.
Have you recently ported your number because there was a post on here and the problem was something to do with previous supplier and the port was not done correctly
Just a throught
HD
