Mobile Phones You can watch or read in sunlight
- Mobile
- Mobile Phones You can watch or read in sunlight
18-10-2018 4:14 PM
Has anyone yet produced a phone you can see or read when there is direct sunlight shining on it. If not I presume the first company to do so will make a fortune selling them
Re: Mobile Phones You can watch or read in sunlight
18-10-2018 4:22 PM
18-10-2018 8:27 PM
Thank you very much I will try that tomorrow I have a feeling it will work
18-10-2018 8:38 PM
18-10-2018 9:27 PM
It's a pity no phone manufacturer hasn't come up with something suitable. Using something similar to nintendo's reflective colour display used on some of their hand helds. Where bright external light illuminates the display and the backlight is just used in dark conditions.
Phones are pretty hopeless in sunshine. Yes you can turn up the lcd brightness to full, which helps on some, and then watch the battery level go down.
18-10-2018 10:04 PM
18-10-2018 11:22 PM - edited 19-10-2018 12:00 AM
True enough but turning the brightness up on them just makes screen burn more likely.
On a really sunny day I guess I could just dig out my old Nokia 3310.
No trouble seeing the display on that on a sunny day. Not that there's a lot to see on it.
- Mobile
