Mobile Data Usage
adrian001
Mobile Data Usage
I am unable to access my mobile usage/minutes data. I used to be able to access this information straight away, suddenly it has been removed
10 REPLIES 10
quelquod
Re: Mobile Data Usage
Works OK for me.
Democracy - 3 wolves and a lamb voting about what to have for lunch!
RebekaPreston
Fixes: 31
Hi adrian001!
Thanks for getting in touch with us!
I'm sorry to hear about this! Can you not view your usage via 'My Account' or do you normally recieve a text notification advising you of this?
- Rebeka
adrian001
I usually get this from my account. All I get now is the information shown in the screenshot.
Colin_Maybe
Fixes: 8
Try scrolling up...
adrian001
No joy
RebekaPreston
Fixes: 31
Hi adrian001
If possible, can you please try this on a laptop or computer and use the desktop version?
- Rebeka
adrian001
It doesn't work! I would prefer to access this information on my mobile.
RebekaPreston
Fixes: 31
I completely understand adrian001, I'm just trying to troubleshoot the issue and find out if this is particular to the type of device being used and one of the ways to test this is to try the desktop version.
If you could possibility try this and try it in a different web browser, it would be a great help!
- Rebeka
adrian001
It works on the desktop version but displays horizontal as opposed to vertical on my mobile.
Colin_Maybe
Fixes: 8
Turn your monitor on it's edge, then they'll be both be vertical.
It works perfectly on my Android phone using Google Chrome (which is what you're using). Try clearing cache & cookies.
