Missing Android OTA updates
Natasha
I recently had to replace my Moto G (3rd Gen) phone and the replacement was shipped with Android 5, when I go to settings to force an OTA update it reports I am up to date as far as your network is concerned.
Given that there are now versions of Android 7 out there for some network customers you seem to be very far behind. Before I moved to you I was with EE and they had the Android 6 update out months ago, my phone is now stuck in the past without the important privacy controls that Android 6 brings.
When are you expecting to offer it or is it simply better that I put another more up to date operators SIM card in my phone to get the update I need?
9 REPLIES 9
Browni
Aspiring Hero
Fixes: 60
Re: Missing Android OTA updates
Is the phone locked or unlocked?
Natasha
Morning,
Thank you for your reply.
My phone is an unlocked phone bought from Amazon.  When I visited the Motorola site for the phone it asks you what provider I am with, but Plustnet isn't listed. All Motorola websites say that they have completed their roll out of 6 and they are working on 7.
Fixes: 1,481
if it's sim free then then it doesn't matter which provider you're with the OTA update should come directly from motorola.
Fixes: 357
There's a long thread here https://forums.lenovo.com/t5/forums/v3_1/forumtopicpage/board-id/447/thread-id/6724/page/1 on the Motorola forums about some 3rd Gen phones not receiving updates. Mostly that relates to not getting the 6.0.0 to 6.0.1 update.
@Natasha If your phone is still on an Android 5.x version then it will not update directly to the current 6.0.1. If Motorola have removed the 5.x.x to 6.0.0 update from their OTA site then your phone will never update. I think you need to register on the Moto forums and ask there how to get your phone to update.
Colin_Maybe
Fixes: 8
@Natasha
I'd select the EE version myself.
Fixes: 357
If that is the case then you should select 'Retail' version.
Colin_Maybe
Fixes: 8
I didn't know that was an option myself but I'd say we have a winner.
Is it just to do with the 'added bonus' guff that the carriers like to bundle in?
Fixes: 1,481
Yes, their 'value added' bloatware the firmware from providers usually arrive several months after the retail versions.
Natasha
Hello
Thank you very much MisterW.
