“Message not sent, phone number fomatted incorrectly”
Chriscottrell
I get the above message when trying to send a text to a non-standard length phone number.
By that I mean a 5 digit number that companies use to do surveys, or report feedback etc.
Normal messages to mobiles work absolutely fine.
Does anyone know what might be the problem here?
I’m using a Motorola G5 Plus, if that makes any difference.
Cheers,
Chris
2 REPLIES 2
Mav
Fixes: 510
Re: “Message not sent, phone number fomatted incorrectly”
'Short codes' are not currently supported by Plusnet Mobile.
There are a few threads on the subject e.g. https://community.plus.net/t5/Mobile/5-Digit-Numbers-not-supported-My-Bank-Payments-are-failing/m-p/...
Forum Moderator and Customer
Mav
Fixes: 510
Moderator's note:
Thread locked in favour of the above link.
