MMS messaging problems
- Mobile
- MMS messaging problems
28-04-2017 10:47 PM
Anybody else having problems sending and receiving mms. I am running an I phone se.
I did contact plusnet help through chat connection but after checking that mms was switched on my phone batted me to Apple they got me to do some checks and a reset and then batted me back to plusnet saying that they may need to update the carrier settings after recent ios update.
So I am still at a loss as problem not resolved. Is it likely to be a problem with sim?
Re: MMS messaging problems
29-04-2017 9:51 AM
Hi @kh1,
I'm sorry to hear you're having issues. Within the Settings of your handset, click on General, Reset and Reset Network Settings. This should reconfigure your phone to our network and update your Data/ MMS service.
If there's still no further improvement, please don't hesitate to send me a private message and I'll look into this further. -Ashleigh
29-04-2017 9:58 AM
You do know that MMS messages are chargeable? Have you hit your smart cap perhaps?
29-04-2017 6:47 PM
I have even done a factory reset of phone no change.
I have had another go at network reset no change.
I have to add I haven't tried to send or receive since I joined plusnet till the other day.
I did port my number from BT which took a couple of days after I had activated SIM card
29-04-2017 6:49 PM
29-04-2017 7:18 PM
Just in case you are unaware that MMS messages (e.g picture messages) are not included in the unlimited text message allowance.
29-04-2017 8:14 PM
And even if there not covered in the monthly contract surely I should still be able to receive or send them
I have to admit it is not a regular thing I would use as there are apps like WhatsApp that can be used. Just someone has tried to send me one and I have tried to reply by sending one back and it hasn't worked either way. Texts work fine
29-04-2017 8:21 PM - edited 29-04-2017 8:22 PM
@kh1 wrote:
Would they not come under the data bit then?
Unfortunately not. They are stand alone billable item when using MMS option one of the reasons why the likes of Snapchat/Whatsapp became so poplar because they only use data which is cheaper
But yes the service should work as expected. Sadly I don't have an iPhone so my experience is limited.
But the Help & Support provides the following for iOS -
iPhone Go to Settings > Mobile or Cellular > Mobile Data Network or Cellular Data Network >
Access Point Names > Menu > New APN. Without changing any other settings, type in the following info: For Mobile data: APN: everywhere Username: eesecure Password: secure For MMS: APN: eezone Username: eesecure Password: secure MMSC: http://mms/ MMS Proxy: 149.254.201.135:8080 MMS Max Message Size: 1048576 Tap the left arrow at the top three times, then press the home button. Check the notification bar for 4G, 3G, E or GPRS. That'll show your connection is working
29-04-2017 8:44 PM
29-04-2017 9:20 PM
Perhaps the information from Apple here will be useful - https://support.apple.com/en-gb/HT201699
30-04-2017 8:17 AM
Morning @kh1,
I can see you've sent a private message, so I'll pick this up and look into the matter further. -Ashleigh
30-04-2017 5:21 PM
I am afraid it isn't as I can't access these settings on an I Phone SE. I could on my old I Phone 4 but not on my newer phone.
01-05-2017 9:42 AM
@kh1 Although it may not be the reason for your issues, since MMS messages are chargeable it doesn't matter if you're anywhere near your limits for data, minutes or texts or even if you've used any of them. It will come off whatever your smart cap is and then once the limit is hit will no longer send. Exactly the same for instance if you were using a premium telephone number.
01-05-2017 12:49 PM
10-06-2017 11:35 AM
me too
Has anyone had any success in fixing MMS when it is failing?
I know MMS is a bit obsolete, but sadly I still need to use it.
I've tried various APN settings and I still can't send any MMS.
Everything else is working fine, and I have credit on account for MMS
Using an Android phone, but that should not influence APN settings.
