Ireland is listed in the roaming help pages as being band 9
FIXEDTopic Options
- Mobile
- Ireland is listed in the roaming help pages as bei...
04-01-2017 3:02 PM
Surely as a member of the EU it should be in Band 1. Can anybody clarify please?
Fixed! Go to the fix.
Message 1 of 2
(862 Views)
1 REPLY 1
05-01-2017 8:37 AM
Hi mikemoate,
Thank's for getting in touch with us.
The charges listed in Band 1 are the same as they are in Band 9. Ireland is listed in a separate Band as it is classed as a different region along with Guernsey, Isle of Man, Jersey and the Channel Islands.
Hope this helps!
- Rebeka
Message 2 of 2
(817 Views)
- Mobile
