Iphone 6S Plus Locked
Wizhunter
Hi.
I have been a Giff Gaff user for quite a few years but changed to Plusnet in the last few days, They made me an offer i couldn't refuse. My problem is i put my new Simcard into my Iphone and it says it isn't supported, Now i am without a mobile and have no idea what i am going to do. I actually thought my Iphone was unlocked but obviously isn't. I got this phone from my sister after she got a new one and i think she was on O2 so that's probably why the Giff Gaff Sim Worked. Any help to sort this problem would be greatly appreciated.
Thanks In Advance
Wizhunter
14 REPLIES 14
Fixes: 1,474
Re: Iphone 6S Plus Locked
Only O2 can unlock it https://www.o2.co.uk/help/phones-sims-and-devices/unlocking-an-o2-mobile-to-use-on-a-different-netwo...
Fixes: 391
@Wizhunter
Why not put your GiffGaff SIM back in until you get it unlocked. As you will be aware, there is no contractual lock in with GiffGaff.
Fixes: 391
As the phone was previously on the OP's sister's O2 account this could be an issue? Presumable she would need to request O2 to unlock it, assuming of course that she is still with O2
Wizhunter
I can't use my giff gaff card as i used my old number on the new Plusnet service and when i put the Giff Gaff card back in it comes back as no service, i totally have no idea what i can do, i don't want to lose my number and i can't use my sisters number as she changed when she switched and the only place i keep her number is on my mobile. Hope this makes sense.
Fixes: 391
@Wizhunter
If you log into your old GiffGaff account you can order an 'extra' SIM card that will probably arrive tomorrow or alternatively pop into a supermarket and buy a £10 top up and get a free SIM with it. It'll have a different number but get you up and running whilst you sort things out.
Fixes: 342
Just try their live chat link from here https://www.o2.co.uk/help/phones-sims-and-devices/unlocking-an-o2-mobile-to-use-on-a-different-netwo... . They MIGHT only need the IMEI...
Wizhunter
I just got into the phone and it's telling me that it was originally EE so it must of been a while ago that she switched and @Baldrick1  I haven't had this number long and have only just updated the 100+ friends and family with it. I am totally screwed i think. New to iphone really as was always android before.
Fixes: 391
@Wizhunter
Are you sure that it's locked and not the APN settings that need updating,  see  https://www.plus.net/help/mobile/mobile-phone-and-voicemail-settings/ ?
I found that this was the case when I couldn't get my MiFi to originally work.
Alex
Fixes: 13
When you put a different SIM in the phone, it it lies and says activating your iPhone, aka "We're talking to Apple's servers to see if your phone is actually locked". If it gets further than that then it isn't.
Apple have attended the Microsoft and Lithium school of error messages. If it moans you need to contact the 'carrier' (aka network as we're in the UK). Does it get further than that and show you a network signal, you can make voice calls? Try that if you can.
Wizhunter
Everytime i insert the Sim it says Sim Not Supported, if i remove the sim i can access internet. I am downloading Patch 14.1 as i am typing here. I will just have to get it unlocked elsewhere. At least i have the IMEI number.
Thanks for trying to help.
PS i just tried the sim again and for a second saw Plusnet, which is weird.
Alex
Fixes: 13
Okay I did cheat and Google this, but I hope it will be of help:
https://support.apple.com/en-gb/HT201328
Sounds like there could be a local SIM lock on the device itself, or on Apple's servers.
If you're using iOS 14 (I am now), it will tell you as suggested in the article whether it is a local lock or a network one. I would try:
If you see this message on your device with iOS 14, follow these steps on your working SIM:
  • Go to Settings > General and tap About.
  • Under Network Provider Lock, you should see a message that says "No SIM restrictions".  If you can't that message, contact your network provider.
If it says it is, it'll be the server level. If not try a working SIM and it may be on the device level.
Wizhunter
Tried that a few hours ago but will look again.
Wizhunter
Just paid to have it unlocked so switching has cost me more than i first anticipated Sad
Thanks guys for trying, i will update as it goes along.
Wizhunter
Alex
Fixes: 13
Should be fine, your network will only pass it onto Apple, who will run a quick SQL query:
DELETE FROM LockedTable WHERE IMEI = {IMEI}
Or maybe if they're feeling adventerious:
UPDATE IMEITable SET IsLocked = 0 WHERE IMEI = {IMEI}.
Even more if they have a provider table or a link table they can INNER JOIN to.
Money for old rope
