Ipad connectivity
Jim_the_rev
Re: Ipad connectivity
Screen pic below.  (no sub-menu 'profile' that I can see.)
and @jab1 : yes, the data button is green.
Fixes: 300
I'm afraid we're going to need someone more familiar with the ipad settings in that case
Aspiring Legend
Fixes: 180
OK, @Jim_the_rev . Next question - does your Mobile Data screen look something like this:
Obviously, the apps will be different, but I'm just trying to make sure all the 'radio' buttons &c are set correctly.
Jim_the_rev
YOU HAVE CRACKED IT!!!
Siri was turned off in Permissions. Duh.
Many many thanks 4 your help and patienc, @jab1 and @MisterW
Jim
Aspiring Legend
Fixes: 180
Jim, glad we've cracked it! But Siri?
As an aside, I am just curious as to why you are using a phone SIM in an iPad - all those I know who use one have data SIMs - they are not paying for the phone element of the monthly rental, and can then get a higher data allowance.
Jim_the_rev
Hmmmmm.  Seemed a good idea at the time / ignorance??? / special deal from plusnet seemed as competitive as others I had seen.  Anyway, it's working, (so's the car)  so time to move onto the next thing.
Many thanks again.
