International roaming bolt on - anything available?
BlueEagle365
I am  going overseas to Jordan later in the year and have looked for an international bolt on to cover a small number of minutes/texts and a bit of data. I haven't found anything so am I right in assuming Plusnet does not offer these?
It's band 6 so really expensive to use (£2.50 min call/£1 min receive, 50p text and £6 mb of data!), I think my best option is to get a local sim for while I'm there and use hotel Wi-Fi for messaging if available.
3 REPLIES 3
corringham
Champion
Fixes: 13
Re: International roaming bolt on - anything available?
The recommended approach is to get a local SIM.
BTW make sure you disable roaming before you leave the UK - my wife recently visited the USA and when she switched her phone on in the USA it used 907MB (catching up with Facebook etc) before she could access the settings to disable roaming. Fortunately she had a £5 smart-cap so it only cost £5 rather than the full £5000+
adamwalker
Fixes: 216
Hi BlueEagle365,
Just to echo what corringham has mentioned, getting a SIM from a local provider would be the most cost effective solution for you. In case you did want to see what our charges are for international calling we have a guide here: https://www.plus.net/help/mobile/roaming-and-international-calls/
 Adam Walker
corringham
Champion
Fixes: 13
I had thought that £6 per Mb was a record breaking amount to charge, but a recent Telegraph article comparing data roaming charges reported O2 charge £7.20 per Mb. The journalist also hit high charges just by switching his phone on.
Those sort of rates shouldn't be allowed - it would be better not to allow any data roaming at all.
