If I use a PAC code to transfer my number should I manually terminate my plusnet account?
MrCalvin
If I use a PAC code to tranfer my plusnet mobile number to another service provider does my plusnet account automatically close or do I need to do something manually to close it?
Thank you
3 REPLIES 3
flanzm
Fixes: 15
Re: If I use a PAC code to transfer my number should I manually terminate my plusnet account?
It should automatically close. I transferred mine out last week and now the account shows as having no number or tariff. Hopefully I should get a final bill soon.
newagetraveller
Just to add, don't cancel the PN Direct Debit until everything is finalised.
Fixes: 1,550
To confirm you don't need to tell us you're moving to another provider, if you port your number away using a PAC we'll automatically close your account and generate your final bill within 30 days.
